Votes
0
Product:
iClone 7
Version:
7.91
Status:
Released in 7.91
Issue 7892
Curve Editor crashes iClone
After the latest update, Curve Editor plugin crashes iClone when started with right mouse click on a clip.
If started from plugins menu, there is no crash, but it does not show any curves from a clip (sampled of course)
OS: Windows 10
  •  6
  •  3017
Submitted by4u2ges May 6, 2021
1 2
COMMENTS (6)
judahcor May 10, 2021
If you run iclone as admin there is no error but the program just closes
Feedback Tracker Admin May 11, 2021
Hi all,
We will fix it soon.
Molly
Reallusion
same issue here as well
Freddymusic May 8, 2021
Same problem with my system.
4u2ges May 7, 2021
Hi Molly,
Yes, you can open it from the menu. And I just figured why it was not showing any curves.
If you have more than 1 clip, it would only show curves for the first clip. There is no way to switch editor to second clip, unless you open it from right mouse click (which crashes iClone).
Feedback Tracker Admin May 7, 2021
Hi nlprod1,
I have transfer it to RD department.As 4u2ges said,there is a workaround that you can open Curve Editor from plugin menu or viewport Right-Menu.
Molly
Reallusion
1 2
