Hi oberdoofus, iClone does not support compressed sound files,if you load the audio file in iClone v7.93,iClone will not crash,but import failed. Molly Reallusion
I also have crashes when importing .wav, even really small ones.
Hi Loir, Can you provide your wav file to us? Molly Reallusion
Hi oberdoofus, I have got it.I will transfer it to our RD department. Molly Reallusion
Hi After a bit more research The problem only happens with .wav files I tried to import into iClone - specifically those exported from Davinci Resolve 17 I recorded and exported the wav files in davinci resolve 17 (fairlight). Which produces best quality for me. I've tried all sorts of wav output settings - Linear PCM / IEEE - different bit depths - I can play them fine individually but they cannot be imported into iClone. However .m4a seems to be OK! - so I can work around it - which is a relief but am curious why davinci resolve .wavs don't work and if anyone has had same issue?
Hi oberdoofus, I can import Audio file.Did it happen in all audio files or some file?Yes only some,please provide your audio file to us.If the file size is larger than 10MB, you can use cloud services such as Google Drive, Dropbox or OneDrive to make the files available to us and put the link in your comment. You can use Private Comment if you want to keep it private.Your help is highly appreciated. Molly Realluaison
