I am having the same issue. Immediate crash when selecting an audio file (.wav) for import in "Create Script." iClone v7.82
Hi vgiacco, Can you provide your audio file to help us identify the problem?If the file size is larger than 10MB, you can use cloud services such as Google Drive, Dropbox or OneDrive to make the files available to us and put the link in your comment. You can use Private Comment if you want to keep it private.
Thank you for your feedback. We will check this issue. Reallusion
Also, installing the latest K-lite codecs v14.6.5 pointed out the unstable codec and asked to remove it. I agreed and iClone has been behaving properly ever since. https://filehippo.com/download_klite_codec_pack/
The audio files were just standard wav or mp3 files that I have been using since iClone5. FL Studio Version 12, released on April 22, 2015 was the culprit. It asks you to install a codec for some of their effects, but is an old program and so is the vorbis codec discontinued in 2012 so is should not be a concern for Reallusion. https://en.wikipedia.org/wiki/FL_Studio https://en.wikipedia.org/wiki/Vorbis
Hi Dragonskunk, Can you provide your audio file and vorbis codec software to help us identify the problem. Reallusion
