Votes
0
Product:
Character Creator 3
Version:
3.32
Status:
Released in 3.4
Issue 7467
Crash on applying skin decal
Basic CC3+ male character w/o dress.
1. Activate the Skin Editor.
2. Switch to 4k texture maps.
3. Apply Acquired -> Scar -> Scar Healed
Crash.
2k maps
or some of the other decals does not cause a crash.
OS: Windows 10
  •  4
  •  1654
Submitted byryobg Dec 3, 2020
COMMENTS (4)
ReMark3Dcz Jan 25, 2021
Hi Tina,
  for final output and/or optimalisation it is precisly what we need. Thank you for this tip.
Anyway for better work with DDS cash in SkinGen mode, what is recomaned, it is graphic card problem?
Actualy I am using GeForce GTX 1060 6G, so it is meant more bigger RAM on graphic card?
Kind regards
Martin
ReMark3Dcz Jan 26, 2021
Hi Tina,
  thank you for Your advice about merge/flatten some layers. I must learn more by manual :-)
Kind regards
Martin
Feedback Tracker Admin Jan 26, 2021
Hi ReMark3Dcz
Here's SkinGen requirement:
https://www.reallusion.com/character-creator/download.html#system-requirements
Looks like GTX 1060 6G is good enough to use SkinGen.
But I think this is just an average using requirement, everyone may stack different amount of layer, and that means different performance environment.
If you need to edit more layer, try to flatten or merge some layers! Those behaviors are irreversible, please save preset before you merge them.
Here's online manual about the function you need:
https://manual.reallusion.com/Character_Creator_3/ENU/3/Content/Character_Creator_3/3.3/15_SkinGen/User-Interface/Flattening-Layers.htm
Please feel free to contact us if you have further question, thank you
Tina
ReMark3Dcz Jan 19, 2021
Same problem with 4K resolution...
Feedback Tracker Admin Jan 25, 2021
Hi ReMark3Dcz
Because dealing 4k texture involves a lot of DirectX resource exchange and DDS cache writing process.
Please try to edit layer in 2k mode then bake final result with 4k texture:
1. Edit texture in 2k in SkinGen mode
2. Deactivate SkinGen mode
3. Toolbar > Modify > Bake All Skin Textures > Select 4096
Tina
Feedback Tracker Admin Dec 7, 2020
Hi ryobg
Thanks for your feedback!
This issue has reproduced in our environment and it will be fix in next version.
Please update the application after new version release.
Regards.
Tina
ryobg Dec 3, 2020
P.S. Other decals from that category also causes crashes on 4k resolution.
