I am experiencing the same issue. Also, changing to Traditional hasn't worked for me. Aha!!! Found it! if you want to change all skin to match (_body,_legs,_arms, etc), 1. change ALL, and i mean ALL, the body parts with the prefix CC_Base_Body to PBR. 2. Check "Affect all materials with the same name" 3. Select one of the body parts and modify the color. all other will change as well! Note: this was on a CC3 character. don't know if it works for CC1
Confirmed. Strangely, if you change the *Shader* between PBR and Traditional, that *will* affect all materials with the same name. Changing a texture map should behave the same way, per Kelleytoons' but report.
