Votes
0
Product:
iClone 7
Version:
7.41
Status:
Assigned
Issue 5515
Changes to the Camera Clipping Planes fail to update the Iray Preview Window
When the camera's Clipping Plane is adjusted, the Iray Preview Window fails to update.
WORKAROUND:
Option 1: If you close and re-launch the Iray Preview Window, the new Clipping Plane values are used.
Option 2: Do some other action that causes a Preview Update, such as zooming in or out.
DESIRED RESULT:
When Clipping Plane values are adjusted, the Iray Preview Window should automatically update, the same as if you move a prop or modify a texture. (Assuming you have "Iray Preview Auto-Upate" ON.)
Thanks to the user "Wires" for doing the research into this issue.
OS: Windows 7
  •  2
  •  1000
Submitted byjustaviking Dec 24, 2018
COMMENTS (2)
justaviking Jan 10, 2019
Thank you for the information about the FAR Clipping Plane.
The documentation (FAQ) plan sounds good.
That still leaves the issue as-reported "Open."
The Preview Window SHOULD UPDATE as you ZOOM in/out, or change the NEAR Clipping Plane.
Feedback Tracker Admin Jan 10, 2019
Hi, justaviking,
We have confirmed with Iray, currently their SDK does not support far clipping plane, so we will list this issue in FAQ.
Reallusion
