Issue 3764
Cant Replace Sprites in Sprite Editor
For some reason in the sprite editor I cant replace the sprites for different angles. I'm trying to create a custom G2 character . First i put the template G2 dummy character in stage and then switch to composer mode. I then click on upper torso and sprite editor button to change it. When i import the new sprite for the front view at 0 degress it succeeds but when i open the full angles settings all of the other angles have the imported sprite with some kind of icon at the bottom right corner. So when i switch to 45 degrees i replace the imported sprite with another and it imports but when i then switch back to 0 degrees view that sprite is also there too.
Submitted bytilmonshieldsiii
Jan 24, 2018
