Issue 6293
Can't change from video render to image sequence render without rebooting
Example 1: I render a PNG sequence, all goes fine and the result is perfect. Then later if I try to render an MP4 video (even from another iClone file, even after closing/relaunching iClone) the video is not created, not even the temporary file for it. The render seems to proceed correctly, but there is no result file.
Example 2: I render a MP4 video. Then if I try to render a PNG sequence iClone crashes.
In both cases rebooting the system allows you to correctly render (until you switch again from video to imgsequence and viceversa)
Submitted byMatt GH
Sep 29, 2019
