Issue 5417
CC3 avatars come in with GI turned on
I don't know if this is actually a CC3 problem or an iClone one, but whether you directly transfer a CC3 avatar over or if you just save it and then drag/drop it into iClone it will come in with GI turned on for all avatar body textures, which is a Very Bad Thing (you can select them all and turn them off, but you should not have to do this).
It's very odd because they are NOT on in CC3 (so clearly this is some kind of problem -- even if someone intended -- wrongheadedly -- to have them on, they should also be on in CC3. But, honestly, they should never be on, as this causes the avatar to glow and otherwise not perform properly).
I don't know how long it's been this way -- I just noticed it recently but tests have revealed it is doing this for every avatar I try (so I don't think I need to give you examples, although I will if you want).
Submitted byKelleytoons
Nov 22, 2018
