Issue 2281
CC2.01 Does Not Respect Marketplace Morph Sliders Sub-Folders
In the Marketplace, if you set a sub-folder for a morph-slider, then when installed the slider will appear in Character Creator 2.01 where it was originally created/placed in CC2.01. The ccslider files, however, are correctly installed into the CC2.01 Template/AvatarControl sub-folder.
1) In CC2.01, create a Actor Parts/CC_Base_Eye morph-slider with a sub-folder, say: "plop/try"
2) Pack/Submit the morph-slider to your MarketPlace.
3) Once in the MarketPlace, edit the morph-slider item and replace the sub-folder with, say: "plip/def"
4) Publish the morph-slider.
5) Remove your original morph-slider from the CC2.01 Custom/AvatarControl/ sub-folder.
5) 'Buy' the morph-slider and install it.
6) The morph-slider will be correctly installed in the CC2.01 Template/AvatarControl/plip/def sub-folder.
7) However, in CC2.01, the morph-slider will still appear under the Actor Parts/CC_Base_Eye/plop/try, where it was originally created.
Submitted byGOETZIWOOD STUDIOS
May 20, 2017
