Votes
0
Product:
Character Creator 1
Version:
1.51
Status:
Released in 1.52
Issue 617
CC 1.51 crashes when creating a morph Sliders
If I want to create a morph slider with the CC 1.51 the Prgramm crashes. i.e. it is closed with an error message. Creating a morph slider is no longer possible. Templates from which I have so far been created slider, the slider create now faulty. However, the body is no longer changing, eyes and teeth. They remain unchanged.
Regards from Germany
Postfosch
OS: Windows 10
  •  8
  •  5371
Bug
Submitted byPostfrosch Aug 7, 2016
1 2
COMMENTS (8)
Feedback Tracker Admin Oct 6, 2016
Thank you very much for your attention.
This issue is fixed and released in Character Creator v1.52
Reallusion
Feedback Tracker Admin Sep 5, 2016
The crash issue has been fixed and will be released in the next coming version.
Reallusion
Feedback Tracker Admin Aug 10, 2016
Hi Postfrosch,
Many thanks for your prompt reply.
We've also reproduced that import the Obj file which was previously exported from Sculptris to create morph slider could cause crashes.
Besides, in order for you to track different types of problems, we suggest to report these issues individually. For example,  Sculptris Obj issue and Second Problem can be reported to Feedback Tracker separately.
And, it would be better if you could divide Blender and Sculptris issues into different feedbacks.
Reallusion
Postfrosch Aug 9, 2016
Unfortunately, I can upload the images / files anywhere
Hello Feedback Team,
I have now tried with their settings for Blender to create a slider from a obj file. It's worked out . Thanks for the settings
The experiment with a obj file to create from Sculptris a slider unfortunately leads on to a crash of the CC
Obj - datein I created only from vorhandnen sliders and it anscließend a neunen Slider create (ohen amendments) will also work.
Second problem:
If I'd create a slider with obj files again which I have created with CC 1.4x the following happens:
The body is in accordance with the of the morph deformed (small, pointed ears, etc)
The eyes and teeth, however, remain in place of the original avatar.
In other avatars arms deform after rebuilding a slider, etc.
I have to insert two images
The two original obj files I add for testing at at
The slider created with 1.4x works but optimal
1 2
