Issue 4061
Built-in Degrain Filtering attribute interfere with Denoiser
There is an attribute in Iray .mi files:
attribute integer "iray_degrain_filtering" 1
It set to 1 by default. I suppose it enables degrain filtering. But in a way it does interfere with Denoiser operation in very ugly way.
Please see enclose images. Both images rendered identically with 250 iterations and Denoiser turned ON. The only difference is, that for the second render I did turn degrain filter OFF by setting attribute to 0:
attribute integer "iray_degrain_filtering" 0
The improvement in render quality is clearly seen.
I would like to request to have a check box in Iray configuration panel so that we can switch it OFF.
This would allow to get a better render quality with less iterations.
Thanks
Submitted by4u2ges
Sep 4, 2018
