Issue 6733
Bug: iClone messes up saved files
Ref: Support TicketID : 174521
As requested by Support, I´m reporting an issue with iClone Save function.
Heiko 3/12/2020 11:18 AM
Please check the attached image. That collection of building blocks was quite an intricate multiple room house (see the floor plan) model a couple of days ago. .. I have complained about this action far back with iClone version 6.
It seems this happens when you make copies of objects. When saved, the original object and all copies revert to some state zero, in absolute same place, on top of each other. They still exist in the props list, but all information about the completed model seem to have vanished.
Heiko 3/12/2020 12:19 PM
From this detail it´s apparent that at save, iClone restores objects to some zero state, maybe from the bottom of the undo stack.
The bluish cube is the 3D basic block I started from. Strangely it has the texture still. So all objects seems to revert to same kind of step 1.
Heiko 3/16/2020 11:02 AM
I have been using the "Save project as" function in the File menu.
NOTE: there was similar behavior/bug in version 6. I contacted the support then, and the response was to migrate to version 7. It seems the cause is still there.
Yours,
HR
Submitted byFyr
Mar 18, 2020
