Votes
0
Product:
iClone 7
Version:
7.91
Status:
Active
Issue 7955
Background Power Performance
When i work on a cpu angry project the fans spin a lot. Of course this is normal. But if I get up from the machine for a few minutes i usually not turn off the computer. Would be fine a power performance function in the background where iclone turning into power save mode if nobody not use the computer after 5 minutes. It's not an important function, but environmentally friendly. The internal Windows power save mode some times not good choice so i hope you can implement this.
OS: Windows 10
  •  2
  •  552
Submitted byFreddymusic Jun 9, 2021
COMMENTS (2)
Freddymusic Jun 10, 2021
This is exactly what happens when I minimize the window, but it is a half solution. Of course I can live with that, so it is not an extremely important feedback from me just an opinion.
Feedback Tracker Admin Jun 10, 2021
Hi,
Currently iClone has the "Reduce Idle Load" , it is similar to the function you mentioned.
GPU|CPU load can be released when your operation events do not happen in the view-port, eg. Minimize iClone window, or operate in other software
you can see the online manual about this feature:
https://manual.reallusion.com/iClone_7/ENU/Content/iClone_7/7.6/04_Introducing_the_User_Interface/Reducing_GPU_Load.htm?Highlight=reduce%20idle%20load
Thanks,
Joanne
