Votes
0
Product:
iClone 7
Version:
7.82
Status:
Released in 7.83
Issue 7339
Any attempt to copy (CTRL-C) a key on the timeline crashes the iClone
Any attempt to copy (by CTRL-C or by context menu) a key on the timeline crashes the iClone.
It happened in all iClone versions since 7.71, on two different computers/hardware, on large and small projects, immediately after project is loaded or far late, on props, effects, also on characters (CC3/CC3+), large or small projects, on Transform or Motion timelines... It was and still is my worst nightmare regarding iClone.
Now finally I've got a project where the crash is happening 10/10 attempts when trying to copy the... very first, default Effect (Contrast) keyframe. Consistent crash, all the time at the same memory address (according to the Windows message box). It happens on any key, but this one is the quickest, simplest and.... most ridiculous one.
I've found on an old report here the "iClone WER Crash Dump.zip" provided by you and installed accordingly, but I was able to get only the iClone logfile, I didn't find the crash dump.
I really hope this would help you to fix this issue.
Many thanks.
OS: Windows 10
  •  7
  •  3412
Bug
Submitted byAmper Sand Oct 11, 2020
1 2
COMMENTS (7)
Amper Sand Dec 2, 2020
Hi Molly
The issue seems to be fixed in latest 7.83.4723.1 - I've tried the same project I've used when I reported the issue,  now is working OK. Also played with few others, again - no problem. So, from my point of view, the issue is fixed and you may close the ticket.
Many thanks!
vali
Feedback Tracker Admin Dec 3, 2020
Hi ampertox,
You're right,we have fix it in 7.83,I'm going to change the status of this issue.Thanks.
Molly
Reallusion
Procrastinator Oct 26, 2020
Please solve this asap. This is pretty critical to any iclone project. I had over twenty crashes for the past 4 hours.
Leowald Oct 16, 2020
Hello,
I get the same problem on any of my projects...! Copy and paste is becoming a fear!
I hope there is a fix soon...!
4u2ges Oct 13, 2020
I managed to fix my project by using "Remove Scene animation" (not an option for ampertox, or anyone else who is already have scene animated).
I still have a large prop (with 230 sub-props) saved. That prop is causing copy key problem, when added to a new project.
Feedback Tracker Admin Oct 21, 2020
Hi 4u2ges,
I have got it.Thanks.
Molly
Reallusion
4u2ges Oct 20, 2020
Hi Molly,
Private check box is not available in this thread because I am not the ticket owner.
I have already sent the dropbox link to Mollychang147 PM at the forum.
If that is you, check the PM, if not, let me know who to send PM at the forum.
Thanks
Feedback Tracker Admin Oct 20, 2020
Hi 4u2ges,
You can use cloud services such as Google Drive, Dropbox or OneDrive to make the files available to us and put the link in your comment. You can use Private Comment if you want to keep it private.
Molly
Reallusion
4u2ges Oct 16, 2020
Hi Molly,
I cannot post this project in public. Please see PM (I think Mollychang is you?)
Thanks
Feedback Tracker Admin Oct 16, 2020
Hi 4u2ges,
Can you provide project to us?
Molly
Reallusion
4u2ges Oct 12, 2020
I can confirm the bug with at least 1 project. It is crushing 10 out of 10, when I use Ctrl+C, or Ctrl+Mouse drag on any key at the timeline.
1 2
