Votes
0
Product:
iClone 6
Version:
6.42
Status:
Hold
Issue 416
Aliasing wrongly displayed when applying Toon Shader
STEPS TO REPRODUCE
1. Launch iClone 6
2. Apply a random prop (e.g. Ball_001)
3. Navigate to Menu > Window > Visual Settings
4. Select "Toon Shader" section and check the box for "Toon Shader"
5. Check the prop
ACTUAL RESULT
EXPECTED RESULT
The shader should be a line without aliasing
OS: Windows 10
  •  1
  •  2391
Bug
Submitted byFeedback Tracker Admin May 10, 2016
COMMENTS (1)
Feedback Tracker Admin May 16, 2016
To temporarily solve this problem, we suggest the following two methods:
1. Method one
● Open Modify panel, select “Edit” tab
● Go to Display > Shadow, click “No Shadow” button
2. Method two
● Open Scene panel, select the object
● Click “All Shadows” to open the drop-down list, choose “No Shadow”
It’s just a work around to help you get good result. We will definitely fix this issue in the coming versions soon.
