Votes
0
Product:
iClone 6
Version:
6.53
Status:
Active
Issue 2193
Alembic Import
This should have implemented at the time they implemented Alembic Export. It's beyond irritating that you implement only half a solution. Alembic import would allow us a much greater flexibility in what we choose to render, for instance, a sequence can be animated in iClone, the motion imported to DAZ, and the character could be returned to iClone via alembic with a much greater presentation because you're able to take advantage of DAZ's JCM's. You've given us half a solution. If you allow alembic export, you should allow alembic import.
OS: Windows 10
  •  2
  •  2137
Submitted bywill2power71 Apr 6, 2017
COMMENTS (2)
animagic Apr 15, 2017
To add to this suggestion, this was recently discussed in the context of importing simulations from Houdini, which would provide quality waves for example.
A good suggestion, which has also been discussed on the forum, but I don't think there is a need for the accusatory tone as that doesn't really make for a stronger case.
