Hi Molly, As I indicated, this problem is unrelated to a specific project. It has to do with the situation after I upgraded to 8.4. I appreciate that this is not something you can repeat and that is it maybe unique to my particular setup. It's is strange though that it happened on two different systems. I just wanted to report it in case others have the same issue. It is OK by me if you close this item as it don't know what further information to provide.
Hi animagic, We can't repeat it.Can you provide your project file to help us identify the problem?Please attach the file in your next comment. If the file size is larger than 10MB, you can use cloud services such as Google Drive, Dropbox or OneDrive to make the files available to us and put the link in your comment. You can use Private Comment if you want to keep it private. Your help is highly appreciated. Molly Reallusion
I "solved" this by reinstalling the content from scratch, that is, by removing the Reallusion Template folder and doing a full install of iClone 8.4. This will recreate the folder structure. This is of course far from ideal.
