Issue 7491
AO / Ambient Occlusion Channel is missing from Compositing Elements list in UI, but randomly renders
Set iRay Render Mode to PhotoReal
Open up iRay Compositing Elements section.
Observe the AO / Ambient Occlusion channel is missing from the available channels UI,
Observe the AO is checked, but disabled in the Interactive mode Only settings.
Render several movies using Photoreal Render Mode
Observe the AO channel is rendered with some of the movies.
This also affects the frame number in the Render Scene dialog. The more channels you select, the more confusing the exported frame numbers become
e.g.
Choosing Frame 100 - 200
will render out frame 50-100
(if RGB and AO are enabled. if RGB, Depth, and Object ID are selected, the exported frames for range 100-200 will be 25-50)
Expected result:
AO is available as an option in the Compositing Elements section when Photoreal Render Mode is selected.
Frame numbers are consistent from UI, export, to output file name.
Submitted byJohnLiebe
Dec 12, 2020
