Combining L1 Force and L2 Structure with Constraint Feature
Combining the dummies from the L1 Force and the L2 Structure categories is simple. By using the Constraint Setting panel, the dummies can be built together. In this section, you will learn how to construct a catapult chariot by applying different dummies from these two categories.
Combining L2 Structure and L2 Structure with Link Feature
Combining the dummies from the L2 Structure category is simple. By using the Link Object feature of the physics control, the dummies can be combined together. The Link Object feature in the advanced panel is different from the Link feature for animation found in the modify panel to the right of your stage. In addition, you can use the Constraint >> Pick Target feature in the Constraint Settings panel (Shortcut: Shift + F10) to connect props in a different way.
The L2 Structure category of the Physics Toolbox contains dummies that can be duplicated to build a system of similar components. By using the Pick feature in the advanced options of the control, these components can start and stop by means of a single control tile. By creating a custom structure with parts of identical names, you may also take advantage of the Pick feature to govern the custom structure with the control tile as well.
