Template Map
Shoes garment mesh texture template.
Edit this in your image editor to create a custom shoes.
The Minimum Bleed Area in the UV reference image indicates you to paste and fully overlap your shoes onto it. This can prevent the result from image-distortion at the side seam of the shoes.
The edges of the same color contour lines will later be sewed together. |
