Flexible scene creation, animated props, day & night, and weather changes, this pack has it all! Thanks to a variety of stage props and character accessories that can quickly enhance any setup.
This pack contains over 150 read-made props, animated props and Bonus props that make it a must-have pack in any comic animators library. |
Combine Use of Hand Accessories with Props
The Bonus props found in the “Buddy Plaza†Pack, can be easily combined with Hand Accessories sprites from the Buddy Build pack to create interesting animations such as; “picking up a lollipop from ground†as shown below. |
How to Change a Scene into a Winter Scene
Simulating a Winter environment is now easy, thanks to the collection of snowy props found inside.
To change, simply select the prop>Go to Sprite Editor>Change to the snowy-version sprites.
How to Change a Scene into a Night-Time scene
Changing any scene into a night-time scene is quick, thanks to the Render Style options. Simply go to the Scene Manager>Select all Items>Go to Render Style>Choose “Affect All†at Color Adjustment> Adjust the Brightness and other options as necessary.
How to Create a Light-Up Window during a Night Scene
After changing your scene to a night scene, go to the Content Manager>Add a New “Window_Inside†and the window prop you want, then > Adjust the “Z†value to determine which prop will be in front of the other prop.
Check out above instruction on how to change the scene to night time.
How to Create a View behind a Window
You can create view behind a window by replacing the “Window_Inside†with the image of anything you’d like, just like the community scene below.
Select “Window_Inside†from the Scene Manager>Go to Prop Composer>Sprite Editor >Import the image>Exit Prop Composer (in Stage Mode)>Enter Sprite Editor>Replace with new image. |
How to Use Animated Effects
Props that have an “Ani†logo in the thumbnail, are animated props.
Right-click the selected prop>Choose the desired action. Check out more tutorials: CrazyTalk Animator 2 Tutorial - iProp Action Menu and Sprite Library
