Certain motions have 3 different parts: Start, Loop, and End. This allows you to customize the length and makeup of each individual motion. Follow these tips to learn more! |
1. In this example, we're applying the Start, Loop, and End motion clips for the "Walk Around" motion respectively. |
2. Make sure that clip looping is toggled on, then drag the clip's right edge to the right to repeat that clip. |
3. Check out comparison below to see the difference between a single loop and a triple loop. |
