Click the download link below to begin your FREE trial download. (See the differences between trial and full version)
Follow
these instructions to install CrazyTalk6 PRO Trial Edition:
1. Locate and run "crazytalk.exe". Click OK to start the InstallShield Wizard.
2. You will see the "Welcome to CrazyTalk Setup" screen Click Next to begin installing the CrazyTalk program.
3. Read the License Agreement and click Yes only if you accept the terms.
4. Click Next to use the default destination folder or click Browse to select a different folder and then click Next.
5. Click Next to select the default program folder; alternatively, you can type in the name of a different folder or select one from the Existing Folders list, then click Next. Setup will copy files to the disk.
6. Setup will complete copying program files to your system and updating the register. You will see the "Setup Complete" screen. Click Finish to complete the installation.
Hardware
Pentium IV 2GHz or higher recommended
512MB RAM or higher recommended
1GB disk space or higher recommended
Duplex Sound Card/VGA Card/Keyboard/Mouse/Microphone/Speaker
Display Resolution: 1024 x 768 or higher
Video Memory: 128MB RAM or higher recommended
Software
Windows 7/ Vista/ XP SP2
Browser
Internet Explorer 6 or above, Firefox 2 or above
DirectX 9 & WMEncoder 9 are required for WMV exporting
* SiS chipsets are not supported.
* Do you experience any problems with "Intel Graphics Media Accelerator" series of graphic cards? The problems are caused by an issue within all Intel drivers above version 14.36.1.4977 (released 2008/08/29). Please update to CrazyTalk v6.01 (21.4MB) to fix this issue.
Recommended Hardware
(CrazyTalk will have better performance in below recommended environment.)
Dual core CPU or higher recommended
1GB RAM or higher recommended
2GB hard disk or higher recommended
Video Memory: 256MB RAM or higher recommended
View CrazyTalk5 System Requirements
| Item | Trial | Full | |
| Program | Time limit | 2 days | No limitation |
| 14 days (after registration) | |||
| Media export with a watermark | Yes | No limitation | |
| Voice import/record limit | 30 min(s) | 30 min(s) | |
| Full length project playback & output | Yes | Yes | |
| Save function (Model, Script, & Project) | No | Yes | |
| Output format (MP4) | No | Yes | |
| Output size | DVD | DVD (Standard) HD (PRO) |
| Data | Embedded Project | 3 | 6 |
| 6 (after registration) | |||
| Embedded Model | 14 | 28 | |
| Embedded SFX | 89 | 163 | |
Copyright © 2009 Reallusion Inc. All rights reserved.
